1 - 1 of 1 Posts
Gents...
I've been having this weird problem where the headlight would turn on the turn signals, dimming on the opposite turn signal when activated, etc.
Well after reading a few posts I started investigating all the recent changes I've made. The one-wire alternator that I hooked up allowed me to rid of the voltage regulator. However, the voltage regulator harness also has a ground that need to be bolted to the frame, which I did not, believing this would not benefit me since I got rid of the voltage regulator. I was wrong. After grounding the wire near the voltage regulator harness all my weird electrical gremlins have disappeared with turn signals dimming, coming on at the same time, or opposite turn signal blinking.
Hope this helps some people to check that ground near the regulator.
Charles
aka ninjakid
1 - 1 of 1 Posts
