On my '65 Fastback, whenever I have the headlights on, my turn signal light stays lit. I have the 3 gauge cluster with idiot lightsm and I have no bulbs out or anything. When I turn left or right the signal works perfect, but upon turning signal off, the light goes back on SLOWLY. Please Help! Thanks in advance.
This is a symptom of an open hot wire grounding to the body, or even a bad ground, somewhere around your turn signal lights. Check the wiring on your front and rear turn signals lights. I had the same symptom on my 70 and it was a bad connection on my front right turn signal light. Good luck. A bad bulb can sometimes give this symptom.
which TS lights stay on - all or the one you just used? try jiggling TS switch and then headlight switch and see if you notice any anomaly. PM me with results if you have questions.
