You must first remove the locks, whether they are inner locking or outer locking. Then, whith all locks removed, I use a big socket (I usually use an impact socket to keep from damaging one) and drive them out with the socket and a hammer. You'll have to drive it to one side until you can remove the cap, then drive it back the other way.
Remove the zerk fittings prior to starting, and put the zerk fittings into the new ones as the very last step.
Yes, you need to remove the caps/bearings to install the new ones. Be VERY carefull you don't knock a bearing out of place or you'll toast the u-joint in about 100 miles.
