Where do you get your no greaseable u-joints?
I'm not having any luck finding a good american made u-joint w/ internal "c" clips and no grease fitting.
I got mine at a local machine shop. They balanced my drive shaft and replaced the u-joints. Perhaps a local shop could just sell you the parts.
Well I called the only place in town that balances driveshafts. (Richmond is such a small town)
They said it will be hard to find them BC they just don't make the internal "c-ring" type without a grease fitting any more.
:shrug:
I'll keep looking.
Discussion Starter · #4 ·
I can't beleive I'm the only one replacing internal c-clip u-joints... :shocked:
Del65 Can you get some from your local shop?
They had them at my local Autozone. I have no idea if they are American made though :shrug:
Brute Force / U-Joint 1-4635BF
Application:
With (2) 3 1/2" yokes
Note:
Rear
Heavy duty U-joint -- lubricated for life with synthetic lithium grease
Rock Auto sells inside or outside clip u-joints made by Precision. You can order with/without grease fittings.
Discussion Starter · #8 ·
I could not find any stating non greasable w/ inside rings.
I found the #507 & #489 premium but no mention of the grease fitting.
