Just keeps them from spinning. I would have welded a flat tab to keep them in place and not welded the bolt in place. Look at the bright side, Now you can get new control arms and bolts.
True, there's really no point in reusing them. Whether you are using replacement arms, or putting new shafts in your existing arms, you should use new bolts.
Ah well that is no problem then. I already have the new uca shafts. I didn’t realize those bolts should not be reused. ?
