After having rack and pinion, all the sloppiness in steering became very evident. I have traced some of it into right side UCA. The ball joint is loose. The wheel can be shaken when the brakes are on, so it is not loose bearings. Although adjustable TCPs would be fine they are also a bit pricey compared to standard aftermarket.
I won't rebuild the old ones, I will buy a new UCAs. What brands have you tried? Somebody wrote about Canadians' UCAs and interference with 16" wheel. Who owns Moog nowadays, is it still the best?
