I thought I had a lead there for a minute when I followed a similar post by bluefinger about a circuit he couldn't identify. But it was a dead end in the end.
My 66 harness has double leads going to the emergency flasher can. The manuals all show only single leads. The extra set, which are crimped into the terminals at the emergency flasher, are the same color as the other set. Orange with a yellow stripe and solid blue. They travel together until they end near the plug in for the steering column. At this point they are cut, so I don't have a terminal type for a clue. They aren't meant for the turn signal flasher, because I have the leads and the turn signal flasher can on the harness and they are connected correctly.
Does anyone else have a 66 harness that has double wires crimped into the emergency flasher terminals? I'm about ready to just tape them up and forget them and never know what they're for.
http://albums.photopoint.com/j/View?u=1575122&a=11977248&p=43129086&Sequence=6&res=high.jpg
66 C-code convertible
66 C-code coupe
65 GTO hardtop
76 Nova hatchback
66 C-code coupe
65 GTO hardtop
76 Nova hatchback
