I'm working on a car where the fuse blades/holders/springy-thingys-that-hold-the-fuses are corroded and generally FUBAR!
I've seen the replacement parts in catalogs and I've read posts where someone has replaced them.... I can't find them anywhere! Can anyone help me out???
Art, you may not want to see how they "repaired" it ::
IMO, I'd replaced the whole harness with either a good used one or a quality repro. I bought a repro engine gauge harness from NPD. It was excellent quality and looked like a factory item. Chances are, the rest of the harness is shot with dried out insulation, ect.
This car was involved in a severe dash fire, the original harness is a mass of melted insulation and corroded copper strands... I have a used harness, repro harness isn't made for a 67 XR-7...
Seems like it may be a canidate for "Painless Wiring!" I believe that is what Laurie used on "Trouble."
maybe treating the contacts with oxisolv would work?
THe terminal contacts on my car were pretty filthy (corroded) when I tore mine apart three years ago. I believe I cleaned them up with some crokus cloth. Maybe a fingernail file. It took some time, IIRC...
If you aren't interested in leaving the vehicle stock, you may want to check out painless wiring's website. I would suspect they could provide a much more servicable solution for your needs...
Just some guy
I'm willing to bet they are beyond repair. I believe the shorts master Midlife has/had the answer
fuse clip thread
