Removed the end caps OK - The O ring was reduced to a rice crispy.
In looking at the threads of the upper control arm, they don't look to healthy and there are metal shavings hanging off - but the caps will still thread in and out and tighten up as if they were not stripped.
Do you think they are still OK?
I dont know...when I consider the investment I put into entire cars, 200 bucks for 2 complete UCA's doesn't seem that spendy
I agree... but I've been saying that all along "what's another $x?? It's adding up to fast!!!! ahhh!
Here's a post from MustangSteve's web site on rebuilding:
Re: Question about rebuilding upper control arm
Posted by MustangSteve on 7/8/2002, 10:59 pm , in reply to "Re: Question about rebuilding upper control arm"
64.156.79.3
Pitch of shaft threads is exactly 1/2 that of the control arms, so they go together just fine. Read my FAQ article on installing upper a-frame bushings. Even if the 1-1/4" hex nut bushings DO tighten up to the torque specified, they will put the threaded bushings in a bind if you do it that way. You should adjust them so they turn freely on the threaded shaft, then tack weld them to the arm. Your misthreaded original a-frames are better than the reproduction unoits in my opinion,and are cheaper to rebuild and better in the long run.
Upper A-Frame Bushing Rebuild
When you remove the 3/4" nuts from inside the engine compartment, retrieve the alignment bushings from each of the 4 bolts (under the fender). Keep track of which ones went where and then put them back in their original locations when you reassemble. Tighten the 3/4" nuts very tight and they won't come loose. The real challenge is getting the new bushings screwed into place with the shaft centered exactly between the bushings and also not putting the bushings in a real tight bind by torqueing the large threaded bushing into the a-frame until it feels tight. The bushings will likely NOT tighten up in the a-frame without bending the sides of the a-frame towards each other. I tighten them until they are all the way in, but not necessarily tight. Then tack-weld every other flat on the hex of the bushing to the a-frame to keep them from backing out. IF YOU DON’T DO THAT, THE BUSHINGS WILL EITHER WEAR VERY RAPIDLY OR THE BUSHINGS WILL UNSCREW FROM THE ARM. (That is not a good thing). Before putting the bushings onto the shaft, take a die grinder with a 1/16" wide cutoff wheel and cut a groove from the end of the shaft, across the threads, cutting slightly deeper than the root diameter of the threads, then into the o-ring sealing area. Do this only on the BOTTOM of the shaft. If you check the physics of it all, that side is never loaded, so it won't cause any additional wear. Deburr the slotted area. That slot achieves two things. 1. It allows the grease to have a path so it can reach EVERY thread on the shaft. Without it, the grease you pump in with your grease gun only gets to the first couple of threads, leaving the rest to give a SQUUEEEEKKK every time you hit the speed bump pulling into the local cruise night. and 2: It gives the grease a pathway to leak (slightly) past the o-ring so it doesn't hydraulically blow out the o-ring when you set the car back on the ground as the threaded bushing turns on the shaft, decreasing the volume of the area where the incompressible grease resides. Nothing worse than watching your brand new o-ring come oozing out from inside the bushing when you lower the car. Before you let the car down, shoot the bushings full of grease, then remove all 4 zerk fittings. Let the car down slooowwwly and then bounce the front end up and down as much as you can. Now, reinstall the zerks and your bushings are properly greased with plenty of, but not too much, grease.
Here's the web site:
http://members.boardhost.com/MustangSteve/
Just some guy
Good one! I saved a copy of that in my personal "how to" files.
