It's odd for this problem to show up with your combination of parts - usually wide wheels, tubular controls arms, or Granada brakes/spindles are involved......
What is happening, is that as your front end lifts, you are getting a bunch a toe-in, and positive camber. In other words, when viewed from the top, the tires point in at each other like this: / \ (toe-in), and when viewed from the front, the tops "tip out" away from each other like this \ /. Correct? Is this what you see when the front end is up???
What are your alignment settings? Many mechanics still try to align to the old settings, which don't work well with modern radial tires. You should be set to:
NEGATIVE 1/2* camber
POSITIVE 1-1/2* caster (2* - 2.5* if power steering)
1/8" Toe-IN
If you car is aligned with POSITIVE camber, I'd definitely begin there! You want 1/2* negative for street driving - tire wear will NOT be adversely affected.
The more caster, the better, although steering effort goes up with increased caster. Increasing caster WILL reduce the amount of toe change. The toe change, combined with too much positive camber is what is causing your problem.
Try running the front wheels without the spacers. How thick are they? Increasing the wheel offset too much thru the use of spacers can exagerate the geometry problems.
Finally, how much toe change do you have? Check the toe in at rest by comparing the width between the front and rear of the front tires. For instance, 56" between the fronts of the tires, and 56.5" between the rears = 1/2" toe-in (too much). Then, with the front in the "up position", measure again. If the is too much toe change, you might look into the
Baer bumpsteer corrector kit. I added it to mine, and went from over 2" of toe change down to 1/8" of toe change - pretty dramatic difference....
