I have a couple that came off of a sealed closed system many years ago. They've been stored in a clean and dry area since then. Can these be used again or just throw them away?
Personally I would reuse them if:
a) I knew the system they came from was in perfect condition with no disintegrating compressor or moisture in the system.
b) I was sure that the refrigerant oil was the same as the system I was installing it into.
c) The filter/dryer was immediately sealed so no moisture or foreign objects could enter.
The folks on here with all the bucks and no worry about a budget will tell you to pitch it and buy a new one.
Some AC shops can rebuild them, they unsolder them replace whatever mistery is inside and solder them back up.
I purchased a new one for my car because it was only approx $35 and found one locally.
But if it is hard to find, I would look into rebuilding it.
No mystery as to what's inside them, it's desiccant. Once exposed, it starts to break down. This is what causes the problems by causing blockages in the orifices.
If they were open to the air for more than a month then get rid of them.
