I have a 67 coupe with an inline 6 that I would eventually like to swap for a v8 but at the moment I don't have the funds for that. My radiator needs replacing right now though and I figured that while I would be replacing it I could just get an aluminum radiator for a v8 that I was planning on buying anyway when I did the swap. Is there any reason this shouldn't work, fitting issues ect?
Make sure the inlet outlet holes are in the right place, otherwise you might need to get creative with hose routing. Also think hard about what motor/front assesoriy setup you want to use. The serpentine setup(which is very nice ie belts always in adjustment if it has a tensioner and 3g alt upgrade easy) uses a reverse rotation water pump with it's inlet on the drivers side, the v belt uses standard rotation and on a sbf it's on the passengers side. Also remember what transmission your going to be running and if your using the stock trans cooler or aftermarket for an auto. Good luck.
Radiator
Rule of thumb is too much radiator is a overkill. If your not going to run A/C in the car ever, then a 2-3 row is fine. Even though its a inline 6, the V8 are the same size other than the rows. A 390 and up more than likely use a 4 row. For a inline 6 thats too much.
