As I have stated in other posts, I am installing a new edelbrock performer on a 302. I want to hook the vacum modulator up to the manifold rather then the back of the carb. Where on the back of the manifold should I hook it to? Does everything else get pluged except for the heater hose hookup?
Mine is just hooked to a vacuum tee off the back of the manifold.
Al
This is not the best shot for the hose from the pcv valve hides the view but you can see a brass block behind the carb. This is where I have both the lines from the modulator and brake booster connected to.
vacuum hookup
