DM289, have seen some dizzies that had a press - in plug, like a freeze plug. But I would ask why are you not running the vacuum ? Better fuel economy and no loss of power, why would a person not want that ? LSG
Not sure if you're aware, but the vacuum advance holds the entire breaker plate from rotating. Removing the arm in the manner you suggest would allow it to move around on it's own. A bracket to secure the plate is needed.
I assume it's a 65/66 distributor and normally takes the metal vac advance line?
Those are tube nuts on those metal lines. I believe 1/8 tube. Eaton still makes the nuts. (6100X2)
Tube nuts like those are straight thread, not pipe thread. They're 3/8-24.
Try an Edelmann 120300.
Thanks for the replies. The reason I do not run the vacuum advance is on the advice of a local speed shop. They set up the advance curve in my distributor and told me to run 16° BTDC and not to use the vacuum advance. The updated distributor felt like I gained 50 HP and the mileage did not change. I was unaware that the vacuum advance arm held the breaker plate, I guess my plan to remove it and make it look closer to the appearance of HIPO distributor will not work.
The '63 289 hp ran a factory distributor housing with the vacuum can on the side. Guts inside distributor was the dual point plate setup. Can itself
was plugged..... looks like a 3/8-24 pan head screw.
Dm289, you need to find another tuner. Yes, a well thoughtout dizzy curve will help power tremendously, but vacuum advance does not cost you any power, but increases fuel economy. There NO downside to running it. Your speed shop is just telling you that they don't know how to set up vacuum advance LSG
Related Threads
Vintage Mustang Forums
4M posts
89.2K members
Since 2001
