1 - 20 of 21 Posts
Guys, I need a vacuum canister for my 68 fastback with factory air. I can't get a hold of Classic Auto Air to find out if they have any in stock and when it would ship. I'm close to getting my A/C up and running again.
So, my options;
1. An alternative that would fit the hole in the fender? Anyone have suggestions for this?
2. Can I bypass it? I know that during hard acceleration / high speed runs, I may lose vacuum. I do not have power brake, so no worry there.
My original canister was shot, so I mounted a universal one from summit in the same location under the fender. Works just fine. Or you can get a repop from CJ pony parts
Summit universal
Reproduction Canister
Thanks for the info. The repo ones from Classic Auto Air ship direct from manufacturer, and I have not been able to speak to anyone there. So, my best best is to go universal. how was mounting the one from summit?
Check with NPD, if you call to order it they will tell you if they have it in stock. Never been disappointed.
I think I’ve figured it out. Looks to be 7/32 vacuum line.
Be careful with a Universal one. The Original 68 has two different size nipples and a built in check valve. You need to be sure it fit the hoses you have and has a check valve or you have to run an Inline check valve.
At some point, I plan to get the classic air version, but for now, the PO used this style one, which I think works ok. They mounted on the engine bay side near the original one. No idea if it has a check valve. They left the original one installed, too bad there isn’t an inexpensive rebuild kit out there.
CAA may buy them direct from the manufacturer, but I'd guess everyone else does, too.
Or pretty much any Scott Drake dealer-
Discussion Starter #9
I can get that exact one from my local parts shop for $40 Canadian. I’m assuming there would be a check valve in that. Otherwise it would defeat the purpose of having a reservoir.
Has anyone talked to with classic Air? Are they open?
I know these cans are available aftermarket. My son has an 85 F150. It has a larger reservoir canister, much larger than my mustang. It looks about the size of a large quart size metal can. I watched a video where a guy made his own, by cutting the lid off the can with a can opener to remove lid. He then got a large can of V8 (quart or half gallon) and JB welded the old top with valves onto the new juice can. It worked great and looked almost original. I cannot find vid with a quick search...but you get the idea. I don’t know if you have old vac can to work with or not? Just a thought from a poor boy!
Discussion Starter #11
No original canister, but a good idea. If I can't get my hands on a correct one, I will spring for the $40 bucks and get the universal baseball looking one. For now, I'm pretty sure I can bypass it to get the heating A/C controls working. I know it won't be perfect, but I desperately need the water valve to close so it stops pumping hot coolant through the heater core. It's like 95 degrees here these days, don't need even more heat!
I believe CAA is the manufacturer, or at least they commissioned them. Note your first link OriginalAir is CAAs división that sells restoration parts and the CJ pony Ad even identifies the part As a CAA part.
Whatever you get make sure it has ribs. I made the mistake of buying a knock off that didn’t have ribs. The engine crushed it to nothing in about 15 mins.
760623
Reactions: Dans68 and coupster
Wow, did not know the engine would squash the can like that...
Ever consider using one of those aluminum radiator overflow tanks with external check valves on the vacuum lines?
IIRC, these were originally a one-item production by an independent operator. Probably long since bought up. But even if the thing is now sourced only through CAA, that doesn't mean they aren't in stock anywhere else.
West Coast Classic Couger has a few used working ones
Ive had good luck with them in the past.
Discussion Starter #18
I got lucky and ended up finding a refurbished one locally.
Very true, but most if not all put a premium on the parts. In all the cases I’ve needed the parts they were cheeper at CAA. Shipping however is not as fast as some places, so when I need it quick Ali call NPD.
WCCC is a first class company. Very good to work with and have some otherwise impossible parts to find.
1 - 20 of 21 Posts
