I am pretty sure I have a vacuum leak. At Idle I am running around 10-13 in h20 and is fairly inconsistant. I have a semi mild roller cam 228/232 dur 597/609 lift 112 lobe sep and feel my idle vacuum should be in the 14-17 range. I have checked and rechecked the carb base gasket and all lines. Carb is new. Engine has less than 3K. I have suspected it to be an issue since I firts fired it up. Next items would be power brake booster and PVC valve. How can i check the power brake booster to see if its OK. Is it as simple as pulling a vacuum on it with a mighty vac and see if it holds? Could the PVC valve be the problem? Any other areas to check.
You can very carefully spray carb. cleaner near suspected vacuum leak area. If engine revs up, you found it!
Use an unlit propane torch, the vacuum will suck in the gas and the RPMs will increase. Added plus to this method, no mess!
You can use a hose and a small diameter tube on the end to get pinpoint accuracy.
A vacuum pump with a gauge works well. The best tool I've found is a 1/2" rubber hose. One end up to your ear of course. The things you hear and how easy it is to locate vacuum leaks will amaze you.
I think that your cam has a little to do with it. That's not a mild street cam for sure. Keep in mind that your initial timing also has something to do with the vacuum.
Good luck,
David
With your cam, 10~13 in/merc isn't out of the question.
I'd check it anyway, just to be sure.
