If a car stumbles at idle a little but runs fine at speed, does that mean it's likely doesn't have a vacuum leak or no?
Thanks.
J. Boggs
most certainly yes. /forums/images/icons/smile.gif
A stumble could be a vaccum leak. When does it stumble? As you start to pull off, or just while it's sitting there? If the condition occures when you pull off it may be a poorly adjusted pump shot.
Discussion Starter · #4 ·
I should have said, it's not a Mustang, but a fuel injected car that idles fine but idles rough in gear with the brakes on but drives fine. Probably needs timed but I don't have the proper tool to get at it yet-German automotive product you see.
Better Question: Why not come to the git-together this PM. Snellville only about 1.5 hours away?
J. Boggs
Sounds like the leak maybe a bad master cyl power brake booster.....check and tighten all lines pertaining to this....
MY 280z had this problem......it also made the car run a bit hotter at idle
good luck!!!
I guess I missed this "git-together", but tell me more. I assume this a VMF group? How often do you meet and where?
Thanks,
