I am in the final stages of my '73 351W into the '68 fastback. However, I seem to be lacking the proper resources to determine how to hook up all of the vacuum lines. When I originally purchased the '73 block, it had a number of vacuum "trees" screwed into the manifold. Upon installing a new edelbrock manifold and carb, however, I have plugged all of these holes to do away with the EGR system.
I called a couple of Mustang shops in the area today, but received conflicting info. On the edelbrock 1406 carb, there are two vacuum fittings. The first is a ported vacuum. The second is a full-time vacuum. Should I run the vacuum line from my single vacuum advance distributor to the ported fitting or the full-time fitting on the carb? Similarly, what should I do with the line from my power booster? Also, do I need any vacuum fittings for my manifold, or can I get away with just the carb? Any advice, websites, or pictures would be greatly appreciated. The car has power steering, brakes, and a five speed.
