I have a rebuilt 200ci motor in my 65 coupe, the PO rebuilt it, and it hasn't been run yet. The rocker arms seem to be really loose, How do I adjust them before I start the motor, or will the lifters take up the slack when the oil pressure builds. This motor was rebuilt more than a year ago, is there anything else I should do before I start it besides prime the oil pump. I have never broken in a 6cyl. before, is it the same as a V8? Thanks.
Just some guy
I'm sure not a 6 cyl guru, but I'll take a shot. When I bought my 67 200 six, it had sat up so long that the lifters had collapsed completely. So far that a couple of pushrods had actually fallen out of the rockers. I repositioned the pushrods (and did a bunch of other stuff) and started the car. It "clacked" horribly for a bit until the lifters pumped out. It's been fine for 4 years since. I never looked further into it as I never use the 6 for anything other than a convenient way to get the car in and out of the garage until the 351W is ready to go in it. This help any?
You are correct. the valves will pump up and take up the slack. Prime the engine first as you would a v8. you should be fine.
Don
