1 - 16 of 16 Posts
I'm tearing down the heads for the 460, and I'm not sure how to go about removing the keepers. I have a spring compressor, but it's not the C type - it's the type you'd use with the heads installed on the block. So I compress the spring, then what? I've tried dislodging the keepers with a socket and soft mallet with no luck. It's a late model head with two little crescent shape clips over the keeper around the valve tip.
Matt Williams
67 coupe, 289
Best guess would be to bolt or clamp the head to the work bench after placing a small wood block under one or each valve. Then pry away.
That's where I would start
Jeff Speegle
MCA Shelby Gold Card
http://www.geocities.com/MotorCity/6473
Mustang & Shelby research, documentation
http://albums.photopoint.com/j/View?u=1609818&a=12284202&p=44925357&Sequence=7&res=high.jpg
Do what Jeff said, use a little screw driver to flick the little
buggers out of there.
BillGear
1966 Mustang Coupe, 302 custom roller cam, holley 650dp,http://www.289mustang.com
http://www.289mustang.com/images/vmfcar.jpg
cool, thanks guys.
Yeah that little piece of wood under the valve so it would bottom out righ away did the job, those little suckers are gone and done for - so now I can go a-porting.
Matt Williams
67 coupe, 289
i'm tired of being a beginner
Matt Williams
67 coupe, 289
i'm tired of being a beginner.
Matt Williams
67 coupe, 289
i'm tired of being a beginner..
Matt Williams
67 coupe, 289
Discussion Starter #8
i'm tired of being a beginner...
Matt Williams
67 coupe, 289
Discussion Starter #9
i'm tired of being a beginner....
Matt Williams
67 coupe, 289
Discussion Starter #10
i'm tired of being a beginner.....
Matt Williams
67 coupe, 289
Discussion Starter #11
i'm tired of being a beginner......
Matt Williams
67 coupe, 289
Discussion Starter #12
i'm tired of being a beginner.......
Matt Williams
67 coupe, 289
Discussion Starter #13
i'm tired of being a beginner........
Matt Williams
67 coupe, 289
Discussion Starter #14
i'm tired of being a beginner.........
Matt Williams
67 coupe, 289
Discussion Starter #15
i'm tired of being a beginner..........
Matt Williams
67 coupe, 289
Discussion Starter #16
i'm tired of being a beginner...........
Matt Williams
67 coupe, 289
1 - 16 of 16 Posts
