My car is in the shop right now getting a full rebuild and while they were turning the motor through they noticed the valves were contacting the pistons. The block is coded D4DE ('74 Mav 302), the crank is a 1M, the connecting rods are C3OE (faily certain that's what I saw), and I'm pretty sure the pistons are stock. Before the rebuild, it had 65 coded 289 heads but don't have the cam specs (assuming stock). Motor ran fine with no issues. The new cam and top end is this: https://www.summitracing.com/parts/edl-2027/
Cam specs: Intake duration: 204 Degrees • Exhaust duration: 214 Degrees • Intake lift: .448” • Exhaust lift: .472” • Lobe separation: 112 Degree • Intake Center Line: 107 Degree • Vacuum: 16”
The kit is designed to be bolted directly to a stock pre-roller 289-302 short block. Any thoughts on what the issue may be? I'll get more specs from the shop as to what exactly is going on and they're going to dig in a bit more, but wanted to see what some possiblities may be. Thanks for the help.
