Anyone know how to put this stuff in right? Looks like I need to take the entire vent window out because of some post that needs to go through this weatherstripping, I've got no idea how.
now that you have the vent window frame out. the vent window is held in with a nut. remove the nut and pull the window down and the pin will come out of the top of the frame. the install is the reverse. just remember the order in which the plastic and other washers come off!
i did forget to say that after emoving the nut and spring, etc. you push the window up so the screw clears the frame and then pull down, for the peg to come out of the top of the frame.
