I've never had a york set up but from a mechanical perspective i am sure this is NOT how it's supposed to sound...
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid654.photobucket.com%2Falbums%2Fuu262%2F05badcad%2FIMG_1078.mp4&title=">
http://vid654.photobucket.com/albums/uu262/05badcad/IMG_1078.mp4
This unit is a reman unit, i can tell because there is still a shinny sticker with a bar code....pretty sure that wasn't OEM in 68 lol.
anyway I have been reading a few different forums but I haven't found the answer and thought someone here might know. The unit is converted to 134. It might just need oil. I know there is a servicing port on top of the compressor unit and people recommendPAG 34 but the servicing procedure is unclear. Some say you have to isolate the case?? I am also reading that depending on how the unit sits that there are different levels of oil needed. Has anyone added added/adjusted oil AFTER the system has been charged?
I haven't ran the compression except for this video and the 1st time I turned it on, heard the noise and then turned it off.
As a matter of fact, the Service Manual outlines checking oil level and adding oil. That's what the bolt in the top-center of the pump is for.
yep I fell like a dumb _ _ _
Info is right there on page 16-30. I will have to take it to an A/C person since the compressor needs to be vac'd after the oil level is checked/adjusted.
Now I just need to find an A/C place that knows what they are doing..
thanks GT
