I just bought a '66 coupe. The title doesn't match the vin that is stamped on the fender. No problem, I checked the vin and the car has no history, which, my AAA agent says, means I just have to go to CHP to solve the problem. However, I can't find out how to decode the vin that is stamped on the fender...6F07C165306. I know there are some real experts here (or at least someone with better books than I have) that can help. Any help will be appreciated.
Discussion Starter #2
Year: 6 1966
Plant: F Dearborn, MI
Body Series: 07 2 Door Hardtop
Engine: C 289 2v V8
Unit: 165306 165306
Is your title off completely or just a number or letter?
You may want to check your door tag as well as the other
numbers stamped under the left fender (passenger side) just to confirm that all the numbers match. Your info is as follows . . .
6 model year
F assembly plant: Dearborn
07 Body type: hardtop
C Engine: 289 (2V)
165306 Basic production number beginning with 100001
Good Luck
RB
