Hi, I have repainted the car now and everything looks good except the glass, it is spotted with water marks from acid rain how do I get rid of this???? Have tried razor blades compound and window cleaners any Ideas????
Opal frost pearl metallic 67 coupe http://www.jps.net/binay/webdocs/febef75b01.JPG
also have a 95 opal frost pearl G/T BOSS edition convertible belongs to swmbo
I noticed when I had my windshield replaced that the glass shop had a bottle of stuff that removes water spots but I can't remember what it was called. I've seen it at two different glass shops so I would think most glass shops would carry it.
Tom
1967 Coupe
Auto w/C4
302 w/Edelbrock 1406 carb and intake
Factory air
http://www.fortunecity.com/marina/kingfisher/1369/index.htm
http://albums.photopoint.com/j/View?u=1581047&a=12070911&p=44629560.jpg
I work in the auto glass industry in AUS.
In my experence I'm yet to see a product that will remove "etched" water marks.
What happens is the "acid" in the water drops becomes more and more concentrated as the water evaporates.
This "acid" then actually eats into the glass surface, giving the edge around the droplet a white apperence , just like real acid etch or sand blasted glass.
The only way , to my knowledge, to remove these marks is to machine polish the entire glass surface.
AS the side and rear glass is toughened , this is very time consuming and most likely as waste of time.
If all the above is BS ,let me know. I have a customer with a brand new tourist coach with the same problem on every piece of glass. I'll import the stuff and make a fortune.
If in doubt give it a clout
If at first you don't succeed , find a bigger hammer
http://albums.photopoint.com/j/view?u=1584152&a=12055089&p=43600042.jpg<P ID="edit"><FONT SIZE=-1>Edited by AussieMustang on 03/24/01 09:40 PM (server time).</FONT></P>
Usually razor blades will work...but try #0000 steel wool and a lot of elbow grease. If that doesn't work, then you'll have to go to real glass polishing compound.
http://clubs.hemmings.com/baymustang/platesmall.jpgLet me check your shorts! My multimeter is just a-waiting! Formerly known as Midlife in the old VMF.
King of the Old Farts *struts*
Discussion Starter · #5 ·
thats what I was afraid was going to have to happen. thanks, John
Have you tried scrubbing the glass with Bon Ami cleanser. This old time kitchen product does wonders for auto glass. GM ,arrghh, recomends it in their owners manuals.Can be found next to Comet or Ajax type products in most super markets
Chris Sowden 1965 Fastback
