Incorporated Sell Out
I have my 351c opened up and preparing to send it out to the machine shop.
It is currently .030 over and I am going to have them hone it out to .040 and then install a 408 stroker kit with dish top pistons. I am going to continue using my 4v closed chamber heads and want to figure out what the compression ratio will be. How can I figure out my total ccs, and/or have I supplied enough information for it so I can get a feel for the total compression.
According the manu of the kit the COMP. RATIO would be as followes for varying size chambers: 63cc =10.89-1, 67cc = 10.44-1, 76cc =9.57-1 with a 4 inch stroke
I come up with 12.12 to 1. That includes bore +stroke, deck clearance of .050, head gasket .035 and a 63 cc combustion chamber ( 3.5515 cubic inches). I didn't include valve reliefs or the side of the piston to the ring, but that wouldn't change it much. My brother ran 4v closed chambers on a 400 and had to run dished pistons for that reason.
If you run that much deck clearance its gonna knock like a son of a bitch... You can't have ANY deck clearance in a closed chamber C and have any hopes of running pump gas.
Dodge- Run zero deck, a standard head gasket, and with the 62cc chamber and the dishes you should be mid 10s to 1, I forget the exact figure (plus when I do my calculating I use 58cc for my Aussies). Zero decking with flat tops ends up with way too much compression, but without getting the clearance to zero it would knock too (no quench).
Discussion Starter · #5 ·
I was planning a zero deck with the dished pistons. Its good to hear someone agree with that /forums/images/icons/wink.gif
