I think (actually pretty sure) I have a leak but am not getting far in locating it.
The motor idles at about 1000 rpm but after warming idles at 13-1400. Mileage is unbelievable bad. Terrible stumble between 2-300RPM unless I am on it...
The only vacuum line I have is for the power brakes and comes off the intake at the individual runners for number 4 and number 8 cylinders. Out of curiosity I put a vacuum gauge on the connect and found I had 20 with a slight pulse. I think the pulse is from this being two individual intake ports.
I checked and discovered that all 16 carb hold down bolts were relatively loose. I had to turn everyone atleast 1/4 turn to make them just good-snug. I only checked one intake (front, near number 5) and it was tight. I have no reason to believe the others may be loose but perhaps. When I installed the intaks I torqued all of the bolts three times. On a Weber set-up this is really a PIA because of clearances to get to the bolts.
I bought some German vacuum leak finder but have not tried it yet. It is supposed to bubble "more" when there is a leak. Depending on time I will try this on Sunday or Monday. I amd trying to finds some spray carb cleaner or starting spray since I am much more familar with using this for vacuum leaks.
Can it be that the carb/manifold gaskets need to be replaced due to the possible leak? Should I seal them?
Anyone have other suggestions on next steps?
