I noticed when I disconnected the neg side of the battery - it energized the frame. I turn my key to run and then I attached my circuit tester to the unconnected negative post and it lit up my tester when I touched the other side of the tester anywhere on the body. Also when I leave open the door it will light up the tester with the key in the off position. Is this normal - some how is the power side leaking to the ground side? A dead short somehere? When I attach the neg post to cable it doesn't light up the circuit. I have get my mulitmeter out and see if there is any volts going to ground (but not enough to light the bulb).
If anyone has an explanation of any kind I would love to hear it.
Thanks,
Dean
Thanks,
Dean
