Just received Osborn’s weld & sealant manual. The shock tower welding pattern is not in the manual! It shows the weld sealant but that’s it. I can count and mark the spot welds as I remove it. What I wanted to see was how the bottom of the shock tower is attached/ welded to the frame rail... can anyone enlighten me?
I replaced the original front frame pieces on my 65 if you want show me what you need to see as far as factory welds and I will take pics of them and post..
I can see it is all spot welds except for the bottom. I haven’t uncovered where the tower meets the frame rail. Is that also spot weld or fillet weld?
1965 Ford Mustang fastback T5 Ncas 9in Locker
Spot welds
