61 - 75 of 75 Posts
· Super Moderator
Discussion Starter · #61 ·
· Super Moderator
Discussion Starter · #65 ·
My first 47" bottle was just south of $200 from airgas, the fill was around $72. Since then I found another local (Miami) small welding supply store that will swap the bottles for $27.
Sent from my Note 4 using Tapatalk
That looks like a 125; 7" diameter.
· Super Moderator
Discussion Starter · #69 ·
Dropped off my 125 cylinder this morning for pressure testing.
Cylinders don't actually go bad do they? I'm assuming that the stamp is just standard protocol?
· Registered
Cylinders can go bad, especially an oxygen tank if it's filled with moist air, it can rust on the inside. If they are dropped and develop a crack or if the threads get buggered up. they may fail it. Tanks get a hydro static test and a visual inspection. But if you take care of them they will last a very long time. A couple of years ago, I saw a photo of a tank that had a Nazi eagle symbol stamped on it, so it had been in service since the '30's
Reactions: Israel
· Super Moderator
Discussion Starter · #72 ·
This was a TIG tank, so hopefully argon doesn't do that, the exterior looks great,.....we'll see.
· Super Moderator
Discussion Starter · #74 ·
Looks like testing gets them certified for 10 years. Got my welder in Saturday. I think my tank got here today, will find out shortly
Got my tank, not exactly as advertised, is around 26" to top of valve and 7" in diameter but still appears to be around a 55 cf tank
What welder did you get and what do you mean the tanks not as advertised?
· Registered
The tank was 26" to top of valve, not 29 like advertised. Also is not 8" diameter, was 7" diameter. The good news is the gas dealer I ended up using (Roberts Oxygen) said it was a 60 CF tank and he swapped it out for me and charged $25 for the gas (Airgas wanted $45 to swap a 60). So I'm happy, $100 for tank, 25 + tax for the fill, and the welder was the Eastwood 135 I picked up on cyber monday for $234 with free shipping, so I am all in for $360.
61 - 75 of 75 Posts
