1 - 11 of 11 Posts
My Napa Gold fuel filter was leaking on my '66. It has a FoMoCo early 70's Carburetor. I was putting on a new Wix filter and the threads broke into the carb. Has anyone else been unfortunate in this and what do you recommend trying to get out the broke off piece?
You could use an Easy-Out to get the busted off threads out. Since it's hollow anyway, this should not be too hard. If things are all boogered up inside somehow, I would get a tap and die set, and put in some Helicoil to repair the threads inside your carb - but hopefully that won't be necessary.
If it is too wide (too "hollow?" and shallow) for an Easy-Out, then try using a bunch of penetrating oil, and a modest sized flathead screwdriver. Drive it into one side of the busted-off threads from the inside until it has a small groove to seat in (use many small taps with a hammer, not big ones) and then try driving it in the direction it needs to turn (counterclockwise). This will take a lot of patience. If you go all "John Henry" on this thing, you might damage the carb itself.
If you can't use an easy out, find a torx bit that will fit in the hole snugly and tap it in. Many mechanic friends have recommended torx bits over easy outs to me.
Hmmm… An early 70's carburetor would have a tapered NPT thread. You might cut them deeper, but not helicoil.
I went to Lowe's and bought this and success!!! But now I still have to go to the parts store and buy another filter.
Thanks to you all.
When installing your new fuel filter do NOT wrap the threads with teflon tape and don't over-tighten. You're lucky you broke the fuel filter and didn't crack the carburetor main body..... or, if you have a leak that looks like it is where the filter screws in there could already BE cracks there. Look carefully.
Why no teflon tape? Dave R.
"Why no teflon tape? Dave R."
Because eventually, Pieces of it will find its way into the carb.
That's why.
:eek:)
Tony K.
1 - 11 of 11 Posts
