After getting a vibration around 3000 rpm, I was wondering if I got a defective flywheel or clutch. Anyways I decided to replace both flywheel and clutch. I used a ford racing flywheel and a king cobra clutch from ford racing.
What a difference, I left some skid marks in front of the shop. My car revs very easy, and it has a lot more power. I was shifting between 5500 and 6000rpms and I still getting more power. Geez I think I really work up this motor when I did the converison.
This converison is a thumbs up in my book.
Those 6000 RPM shifts are fun.... right up until a rod shoots out the side of the block. But I'm with you, 5.0 motors are cheap enough that I can change one out a few times a year.
Light'em up and enjoy those shift points!
Dave
Dave,
Very cool. So you think it was the flywheel?
Way to go Dave...only 6000? :thumbsup:
Dave
Spun my 289 to 7200 that I had in a fox body with a 5 speed. ARP rod bolts and main studs goes a long way :)
I shifted at 7,000 but it would hit 7,200 all the time before the shift was complete. 302's don't like the RPM because it puts a heavy load on the skirts of the piston. If you ever had a stock 302 you beat the tar out of, you'd likely find cracked or missing skirts when you take it apart.
Wasted a 302 doing just that, bore was egg shaped from the missing skirt.
