I use a stock, 6-bolt bell housing on an early 302 with a spacer. It is all easy to modify and if you keep the Z-bar lubed, it is smooth. People here have lots of preferences, and I understand that cable is just fine. I just don't know all that much about it. The stock flywheel from the 400 truck engine is what I use. They are the same size, just drilled diffrently to accept an 11" clutch set. I also have flywheel that I am prepping for the next engine that will (hopefully) go in over the holidays. I have 166,000 miles or so on this build. Except for the Centerforce product, it's been all good. Who knows, it might have been defective, but others have had bad experiences, too. From experience, I recommend a diaphram pressure plate as I mentioned. Since you are near stock, you can likely use a stock rated unit. I like Qualitee. But make sure that it is a good clutch set and that you have the pressure plate balanced or at least checked for balance at an engine shop. It is not fun to have to keep pulling them out until you get a good one.
