Hello:
Dear Friends.
I have always had a question with my 69 mustang.
I would like to know which instrument or accessory is the one that goes near the ignition key, as shown in the attached photo and which blue frame.
Thank you in advance for your help and comments.
753939
Right there in the 69
753942
Owners Manual.
Thanks....great.
This is the exac intrument panel of my car.!.
I'll find out how to restore that signal
Is the first picture the panel on your car? If so, the one Brian posted is not same as yours as that one is a tach gauge. But the light you are inquiring about is correct. If your parking brake light is not coming on when parking brake is engaged, check the bulb and also check the switch which is installed on the parking pedal mechanism. It is located close to firewall and I suspect your switch is broken which is a common problem. You can find used switches, also I reproduced a few of those switches that are used on 69-70.
