This electrical metal tube thing was dangling from under my dash and I have no earthly idea what it is. It's about the size and shape of a pinkie finger, only shorter. It has a hole drilled in the side and part of a clamp around it. View attachment 847039
It was hanging down from under the dash above the gas pedal. One wire is grounded just behind the heater controls.Courtesy light? More pics would help. Where under the dash?
ash tray light.This electrical metal tube thing was dangling from under my dash and I have no earthly idea what it is. It's about the size and shape of a pinkie finger, only shorter. It has a hole drilled in the side and part of a clamp around it. View attachment 847039
I see. It's a shift indicator light; probably burned out. It doesn't want to come apart in order to access the bulb. Hardly a critical item. A new assembly is kind of pricey, and I don't know where it is suppose be installed anyway. I guess I'll just stick it back up under the dash.LIGHT AND HARNESS, SHIFT INDICATOR - #15A808-1A - National Parts Depot
Buy part #15A808-1A LIGHT AND HARNESS, SHIFT INDICATOR for your classic vehicle from National Parts Depot. Free shipping on orders over $300, fast delivery & everyday low pricing! Order now!www.npdlink.com
It's a 1970. The ignition switch is on the column.Which year model? If '69 it could be the light to backlight the ignition switch. Possibly an ash tray light. The LtBlu/Red wire indicates that it is in the circuit with the dimable dash/instrument lights.
On a 1970, that is the ash tray light.It's a 1970. The ignition switch is on the column.
Maverick beat me to it. It it’s the ashtray light. ($25) I would not just tuck it up there. Disconnect it from the wiring harness. There should be a plug a few inches back from the light. You don’t want something with power going to it bouncing around under the dash.I see. It's a shift indicator light; probably burned out. It doesn't want to come apart in order to access the bulb. Hardly a critical item. A new assembly is kind of pricey, and I don't know where it is suppose be installed anyway. I guess I'll just stick it back up under the dash.
Yeah, I just bought this car a few weeks ago and thought it was rust free. There is significant rust inside, however. I wasn't expecting that - no rust on the outside and rust inside. It looks like it has been leaking from the windshield seal, but it had not occurs to me to check for a cowl leak. Thanks.Maverick beat me to it. It it’s the ashtray light. ($25) I would not just tuck it up there. Disconnect it from the wiring harness. There should be a plug a few inches back from the light. You don’t want something with power going to it bouncing around under the dash.
What concerns me is how rusted it is. Possible indication of a cowl or windshield leaking. It’s not normal for water to be damaging things under the dash unless you have a good sized leak.
Well if it is shorter than a pinkie finder you know how to reference the size.......It's about the size and shape of a pinkie finger, only shorter. I
Unfortunately many a Mustang has rusted from the inside out. The early Cowls leak (Don’t know about later ones which can be opened and cleaned). So do the front and rear Windows when the seals dry out. All that lets water get to areas that are not well protectedl Carpets and other material hold the water against the metal and allow rust to form. Then it’s mearly a matter of time. 1st the floors rot, then the toes boards, followed by the cowl, frame rails, rockers, and eventually the door posts. Hopefully your’s is not too far along. If the window is leaking, the frame around the window may have rust damage too. I had to repair quite a bit around the edge of a 65 fastback window that had leaked into the trunk causing lots of damage. Until the window was removed the damage around it was hidden.Yeah, I just bought this car a few weeks ago and thought it was rust free. There is significant rust inside, however. I wasn't expecting that - no rust on the outside and rust inside. It looks like it has been leaking from the windshield seal, but it had not occurs to me to check for a cowl leak. Thanks.
