whenever i try to use my turn signals my tail lights act as the emergecny flashers,anyone know whats wrong?thanks -Pete
Wild guess...bad turn signal switch??
*G*
Looking at my wiring diagram, unless some of your wires got together, that's the only thing that makes sense.
Maybe Midlife will stop by...
my indicator lights on the cluster work fine though,could it still be the switch?thanks -Pete
Both left and right side lines are somehow tied together, possibly by a bad ground on either or both sides.
Work methodically getting one side done by disconnecting the other side. Check all grounds, and then resistance from one hot line (left) to the other (right). Should be well over 1 kilo-ohms.
