1 - 10 of 10 Posts
I wanted to know what kind of electric fan from what kind of car will fit in a 67 mustang with a 302. I got one from a 3.8L Taurus which was supposedly supposed to work...but no. Things never go how you plan them. If anyone has anyinput on this let me know. I am looking for a stock fan from some car I can get at the junk yard for cheap. I am a poor college student. THanks guys.
What's wrong with the stock setup? Heating up at idle in traffic? A pusher fan (in front of the radiator), along with the stock fan, may cure your cooling woes.
I have a taurus fan in my car. Taurus' have 2 different kinds. One is a single speed and is much thicker. The other is the dual speed and is a flat pancake type. I used a dual speed fan. I can't tell you what year Taurus it was. See my
web page. http://www.knology.net/~fastback67/fnewfanoutside.jpg
Before you go to an electric fan, have you investigated into why your car is running hot?
Is your timing set correctly? Is your radiator clogged? Thermostat malfuntioning? Lower radiator hose collapsing? Radiator cap failing?
You don't say why you want to swap to an electric fan, but if it's because of overheating you might look to the above common problems first. If all of those are OK, and your motor is not super modified, a stock setup with a shroud should cool pretty well. Good luck ! Dickson
Discussion Starter · #10 ·
It's the fact that I have almost 400 horsepower with a not so good radiator. It used to overheat at times but now it does it a lot more. Timing is set correctly and all the other stuff is good it's just the radiator isn't up to snuff. Once I get the funds I'll get an aluminum radiator. And the reason I want to put the electric fan on is to free up some power.
1 - 10 of 10 Posts
