I have been looking to buy a fan shroud for my 66-302 mustang. I had a little cheap metal shroud on before I put in the 302. The old one would sometimes rub the fan blade. I see that mustang parts dealers sell metal ones and plastic ones. Which one is better and where did you buy from? Also which size 3 1/2 or 4 in.Thanks,Tony
When I installed my FRPP 302 one of the things not fitting was the fan shroud. The fan was from a '67 289. I got a fan shroud kit from Classic Auto Air. It has a smaller fan but compensates by having six blades. The CAA fan and shroud work fine although the shroud is a little metal one like the one you have. Its dimensions may be slightly different than the aftermarket shroud kits found at Mustang vendors.
Thanks Geegee,I have problems with my car running hot.I have a 4 core radiator and the car when its above 85 degrees out side the needle on my gauge is almost on H. I put a new senser on it.Some people tell me cause its a new rebuilt motor it will run hot till its broke in.I never had this problem with my 289.Tony
