The 'stang we have came without a driveshaft.
It was a 289 3speed, it will be a 428 with a 4 speed toploader or more likely the 5 speed TKO 600 from DHP with the shortened input shaft, so I can bolt up to the Z code bellhousing that I have.
Has anyone there got this combination? I understand this will allow me to use a stock length big block drive shaft.
Thanks for any insight
I'd say you should get out the measuring tape.
IIRC, the way to figure the correct length is to install the yoke and measure from the front u-joint saddle back to the diff yoke...then subtract 1" to get your driveshaft length.
The factory 67 289 hi-po, 390 & 428 driveshaft for a 4-speed was 50 1/64" long (center to center of the u-joint yokes), 3" diameter.
Vendor
Install the yoke into the transmission as far in as it will go. Now, pull it out 1" - 1 1/2". With the weight of the car on the axles, measure from the center of the rear end U-joint, to the center of the U-joint on the yoke installed in the transmission.
http://www.streetortrack.com/images/driveshaftmeasurment.jpg
