I have a 1967 GT350 with the stock z-bar clutch linkage. I'm currently using a white lithium grease to lubricate all of the bushings (clutch pedal pivot, clutch rod, etc.). It doesn't seem to last very long. What do you guys use?
I've been using wheel bearing grease because it's thicker.
Next choice would be brushed on Lubri-Plate.
I drilled & tapped my z-bar and installed a grease fitting. I packed it with grease before installation and everytime I grease the car I just put in a few pumps. I use lubriplate on the other joints.
Dan
i used white lithium also. i believe it still lubricates even if it looks like it dissappeared.
