i have a 67 and im putting disc on the front and leaving the rear drum. i dont know what type of master cylinder i need to use or where to find one. p.s. i have a manul master cylinder on now.
If your going to leave them as non power brakes, the one your using now should be ok.
There are many you could use, but.... since 67's had a disc brake option, get the disc brake MC for a 67.
If money was not a real big concern, I would compliment my new disk brake set-up with a power brake master cylinder. I was going to do it with my all 4 drums, but the guys at mcbrakes.com said it probably wasent a good idea with the drums up front, alot of people I guess had problems with pulling to one side and unsatisfactiry performance. When I get some finances together, the disc brake upgrade is my next big project, and I am going to get the power brake booster with it. I did however upgrade to the dual chamber m/c from a 67, which like the other poster said, will work fine with your car. I went ahead and replaced the front brake lines in there while I was at it. Picked up some pre-bent ones for about $30.00, stainless steel. Good luck! James.
