I am painting the grill of a 65, the egg crate type. It looks like it has a flat black paint on it. Of course, it could be that it is just old and faded..
What color and type of paint should I use?
The correct color is a bluish/gray that is available from most part suppliers (I get mine from NPD). The uprights, the vertical parts that the grill bars attach to, should be semi-gloss black. The attaching tabs on each end of the top should also be semi-gloss black.
I will get the paint from NPD on my next order.
So the other parts were painted prior to being rivetted in? Interesting.
Yes, all parts were painted separately and then the grill was assembled. I have seen original grills with the rivets on top either painted black or with the bluish/gray paint swiped over the rivet head. When the bluish/gray paint is used to cover the rivet heads, the color is usually noticably different and there are brush marks present.
January 65 Dearborn car, unrestored car, black grill rivets
