1 - 11 of 11 Posts
I recently purchased a bunch a parts from an owner of a 66 coupe. I couldnt identify these parts, however. Any help would be appreciated. Please forgive my ignorance!
769892
The middle part is a brake distribution block. The part on the right is a master cylinder pedal rod. Not sure about the part on the left
Factory KH proportioning valve used on -'66 cars with disc brakes. Not available as repro and worth some money. Also found on 60s Corvette.
Yes, definitely has value even if it needs rebuilt !!
Reactions: thestang66
I wonder if the PO was stockpiling parts to convert to disc brakes? If the proportioning valve doesn't leak, you got the hardest part to find unless you go with an aftermarket one.
1965 Ford Mustang fastback T5 Ncas 9in Locker
Yes proportioning valve is valuable, also used on 65 as well as 66. Shelby and mustangs with front disc
1 - 11 of 11 Posts
