1 - 13 of 13 Posts
I am starting the 6 cy to V8 conversion on a 1966. These are the parts I have; what am I forgetting?
Springs
Shocks
Upper Control Arms
Lower Control Arms
New Strut Rods
Inner and outer Tie rods.
Heavier sway bar
Pitman and Idler arms
spindle assembly
new brake lines and hoses
5 bolt rims
Seems like that should be everything. :p
I agree with Al, centerlink/draglink......
You should have it all back together BEFORE the September project day? ::
Discussion Starter · #5 ·
With the way some of these bolts are rusted, I hope I have it all apart by then. ::
Discussion Starter · #7 ·
Those are part of projects B & C. I'll do rear suspension next.
The UCAs, LCAs, and Strut Rods are the same for 6 and 8 cars. The only reason to replace the CAs is if the bushings and/or ball joints are bad/damaged. Unless the strut rods are damaged you should only replace the bushing if it's shot.
Make sure torch is on your tool needed list :)
Discussion Starter · #10 ·
These parts are original to the 6. The passenger side lower control arm has a couple rust holes through it. :: So replace all just to be safe.
Discussion Starter · #13 ·
I'm using the Baer Tracker bump steer tie rods; they don't need the sleeves. Thanks though
1 - 13 of 13 Posts
