i appologize for my ignorance but this is my first automatic transmission experience.
i have deceided to go ahead and rebuild the early model C4 out of my 68 coupe.
someone had previously directed me to this rebuild kit
http://www.broaderperformance.com/index.html
i started searching around comparing prices mainly, since i dont really know what im looking at, but summit seems to carry B&M and TCI rebuild kits.
i plan on putting a 350 horse 302 crate motor in the car. it will be a street use car only with usual horseplay.
any kits better then others??? what to look for? what to avoid?
TIA, again im sorry if this is repetative, but i want to make sure before having to do something twice
The soft parts or seals and stuff are probably close to the same. The main difference are the frictions and steels. Jay @ Broader gives you a bigger direct clutch and adding more clutches to a certain extent will allow you to handle more power w/o burning it up. The kit I got from him I think had Raybestos clutches. You also can't beat the free support. I had to call him about a couple of questions and he always had the answer. Since this is your first rebuild I think he is a great option. Maybe if you had a few under your belt, the other ones might save you a few bucks. I called him and asked similar questions a week before I bought. Call him and ask. JMO
ok thanks, i did email him and he made that 500 hp kit recommendation, and he did seem very nice and knowledgable just wanted to get some more opinions
thanks
Any of the three kits you mention should work fine for street use. In addition to the standard rebuild kit, I would recommend a sprag rebuild and a new reverse servo piston. These are typically not included in a rebuild kit...
The C4 is easy to rebuild; but you must be clean and organized. The Haynes manual is helpful too.
Good luck,
Rory
