1 - 2 of 2 Posts
@Shaun
If I run with this set up, what size tire would be best. Canyon carving '68 coupe build.
SoT Front Bilstein Coilover System (Sport, shaft bump stop, camber kit, Moog ball joints) and Big Spindles.
SoT 13x1.25" Rotor 4 Piston Forged Aluminum Caliper Brake System. (New master cylinder, maybe power booster residual pressure valve...)
Maier Racing wheel 3.5" Flares.
Vendor
Thank you for your message!
A regular 68 with stock fenders could run a 8" to 8.5" wheel up front with rolled fenders so if you flare it you could effectively add the width of the flare to that depending on the shape of the flare and if it has clearance. I think a 10" to an 11" wheel would be awesome!
1 - 2 of 2 Posts
