1 - 12 of 12 Posts
Currently have a C4 with the short AC console. Will have to change the shifter plate to a manual but what shifter handle works well in this conversion?
Not to be flippant, but I think any shifter handle would work. That said, I recommend one that has plenty of angle to it. I got a Hurst shifter handle and it's a high quality piece, but ultimately, it's a little short. I'm tall and have my seat moved back, and I have to lean forward a little bit to shift. Not enough to justify a new shifter (I'm cheap), but if I had it to do again, I would get one long enough with enough backward angle to mimic the stock shifter. Just to be clear, I like the Hurst brand, I just ordered the wrong length/angle.
I used a Steeda Triax T5 shifter and bolted on the aftermarket stock looking Ford 4 speed shifter handle without issue.
I’m using the Hurst shifter/Tri-ax handle from my 92. I made a plate that offsets the handle rearward. I have the factory a/c console (c4 originally). I used NPD’s cheap manual plate for a driver. Contours slightly off but decent quality. I was able to easily cut the plate for a/c console with portable bandsaw. I used painters masking tape to minimize scratching and minimize chrome chipping...it will be covered by the trim cap anyway.
+1 for a Hurst Competition Plus handle. I mated one to a Pro 5.0 shifter
I will add that you will want an aftermarket shifter for the t-5. One option is the summit brand shifter with the handle of your choice. Mine came with a Steeda handle and I would swear it is a Steeda shifter for about $50 less. Works much better than the stock one.
Here is mine, console not shown but fits fine. Has OEM reverse lockout pull but it is for appearance only and not functional.
739696
I went with an 8” angled machined billet handle for my pro 5.0 short throw shifter. Think I paid $50 from eBay. It’s very comfortable, and looks killer.
I don’t know my specific shifter, but I have a Hurst handle and cue ball shift knob. For the boot, I modified a stock 4 speed boot and bolted it directly to the tunnel and cut it slightly to fit the new arm. Then I bought a leather boot that fits loosely over the rubber one but tucked it underneath the console. I love it and it works perfectly.
OK, I have a Non-AC console and went with an MDL recommended shifter. It's designed to "pop-up" through the existing C4 opening and it does/did. I purchased a bezel kit designed for a manual shift in a car with a console. It integrated well within the console. However, the corrugated rubber boot did not fit well and would "hangup" 2nd gear at times. So, I went with a nice leather shift boot on it and it's worked nicely.
1 - 12 of 12 Posts
