Looking for advice on what to do with the 20" radiator removed from a '67. I don't know if it was original to the car or not. Recycle it? Sell it?
This radiator was leaking again not too long after I spent $100 having it repaired at the bottom tank hose connection. The radiator shop wanted $300 additional to boil it out and re-core it. I didn't think dropping more money into it was a good idea, so I replaced it with an ACP reproduction. jp
763891
763892
depends, i would keep it in inventory and if you run across someone that needs a radiator, sell it to them for say $50. just let them know that it needs to be recorred.
Check the numbers on the top tank. If they are correct, some Concours guy would pay more for it than you would get at a recycle yard.
Save it and put it on a shelf in your garage. When and if you sell the car someday some people will want originality so give it to them with the sale.
I'm beginning to think this may be a reproduction radiator. It doesn't have FoMoCo, or a date code stamped on the top tank, no part # on the folder-over strap, and no numbers on the side straps that I see. This is a Mutechen, NJ plant car. jp
So, giving away PRIZED information.
As much as people chatter about original radiators, I have sold 1 in 15+ years of putting them on ebay. Unless it is a Shelby or Cobra Jet or Boss type radiator, no one will pay much for them.
For recycling, as is, it is a dirty brass radiator, and (making up numbers, because it varies a lot geographically), it might bring 90 cents a pound due to the steel.
Now, take 5 minutes and a cold chisel, you can crack the solder joints, top and bottom, and the steel sides just peel off.
The radiator is now 14 ounces lights, and it brings $1.90 a pound. It is brass and copper.
Or take a sawzsall or hack saw, takes 2 minutes with my Ryobi, to cut off the top and bottom tanks.
Now the tanks bring $1.90 a pound, and the core brings $3 a pound.
This makes a huge difference in scrap value, and if you bring it as is, the guys in the back, after you get your 90 cents a pound, will cut it up and pocket the profits.
At swap meets, this is what I call GAS MONEY. Finding an old beat up heavy Chevy Truck radiator, that weighs 50 pounds with crud in it, obvious leaks or damage, selling for $20.
Buy it, toss it in the truck, 5 minutes or work, drop off at the scrap yard, for $110.
Finally got around to taking the radiator apart. Got $12 for it from Alter Trading Corp. Could have gotten a couple of dollars more if I had removed the two auto-trans and drain fittings from the brass bottom tank. They'd only pay mixed scrap price for the bottom tank with the iron fittings on. They paid $1.35/lb for the brass and copper. The core was itemized as "Auto Radiators." jp
