1 - 20 of 23 Posts
1966 289 3-speed
My brand new tires have a couple of brown stains on the white walls I'd like to remove. What's a safe way to get them clean?
Tire Wheel Vehicle Automotive tire Synthetic rubber
Hopefully the stains are external and will clean up with Bleche-Wite and a scrub sponge.. Problem may be "bleed through" of the black rubber beneath. It causes "browning" of the white wall. The transition away from whitewall tires have resulted in many historic brand abandoning them, leaving off-shore tiremakers for manufacture. Unfortunately they do not make them the same way and the bleed through occurs.
^^^^This exactly. It's a known problem admitted to me by BFG. Alas, their "offer" for replacement was not much of an offer, basically a FU. I get the SOS pads and scrub brushes out every couple of months to temporarily get rid of the brownness. YMMV
Tire Wheel Motor vehicle Car Automotive tire
Tire Wheel Automotive tire Locking hubs Tread
Tire Wheel Automotive tire Locking hubs Vehicle brake
Tire Wheel Automotive tire Car Locking hubs
I gave up on the bleed through stains on my TigerPaw whitewalls and painted them. About 500 miles so far and they still look good. I haven't scrubbed the tires yet, so I don't how durable it will be.
The SOS pad does work well as does Comet/Ajax bathtub cleaner.
Bleche White used to work when it was made by Westleys but is lacking ever since the Black Magic name went on the bottle.
Meguiars Wheel/Tire cleaner works great on whitewall or white letter tires.
This is what I use and I always make sure the wheels/tires are wet first, and don't really use it on the wheels, just use car soap for them.
To finish them up. I use Aerospace 303 or Aero Cosmetics Rubber Care.
Liquid Bottle Fluid Drink Font
Dab a rag with lacquer thinner and no scrubbing involved. Just a light wiping and the dirty white turns bright. Works on my BFG T/A's. I also use Bleche White for light clean up.
My brand new tires have a couple of brown stains on the white walls I'd like to remove. What's a safe way to get them clean? View attachment 809575
I used to use Ajax or comet cleanser with a natural soft bristled brush (the kind with a wood handle).
Soak the brush, sprinkle the cleanser on the bristles and scrub the wetted tire. Cleans very well without scratching the rubber
In the old days I used to use dishwashing liquid mixed with some warm water and use a cracked of piece of stone from a center-block and press and scrape the dirt out of the white raised letters. They would be so white afterwards and the soapy water would keep the stone and letters lubricated enough that it wouldn’t mess up the paint on the letters. Did that for years.
1966 289 3-speed
Discussion Starter · #14 · (Edited)
Well neither comet cleanser or lacquer thinner did anything. Also comet cleanser made a damn mess and gets in every groove of the tire. I would not recommend it. I'll try bleche-wite but I'm not hopeful.
Well neither comet cleanser are liquor thinner did anything. Also comet cleanser made a damn mess and gets in every grove of the tire. I would not recommend it. I'll try bleche-wite but I'm not hopeful.
Did you try the SOS pads?
1966 289 3-speed
Discussion Starter · #16 ·
No. I just tried what I had on hand. But I'm starting to think this is bleed through and not a stain that can be removed. The white areas look thin in a few places so I'm not keen on using an abrasive like sos. I'll pick up some bleche-wite on my way home and try that.
I've heard people who own early 20th century cars, like a Duesenberg, run nitrogen in their tires to keep those massive whitewalls from discoloring. Not sure if it's valid or a myth, but this discussion has me wondering. And it would be the only reason to run nitrogen in street tires.
1966 GT 4spd
Yes I always used Comet or Bon Ami with bleach and a stiff brush. Never had any issues with removing it with a hose.
Chris
SOS pads and old fashioned elbow grease (not the product I found on the internet)
1 - 20 of 23 Posts
