1 - 10 of 10 Posts
I can't say for your rims, but for the Legendary GT9 (Shelby 17") rims the factory center caps are too small and you have to use the Legendary caps. I was able to use my factory lug nuts.
Pretty sure you need to use there center caps - look at there site and it will give you the diameter.
From the NPD Web site:
ADAPTER KIT, Legendary Wheel Center Cap, required when using a Legendary cap OTHER than the 1130-48A on the Legendary 1007-34 series GT9 wheel, one kit required per car
Manufacturer Reference #'s: LW-HC69A,
Vehicle Applications
1965-1973 MUSTANG W/ 1007-34 SERIES LEGENDARY WHEEL ONLY
1967-1973 COUGAR W/ 1007-34 SERIES LEGENDARY WHEEL ONLY
1960-1970 FALCON (BEFORE 1/1/70), W/ 1007-34 SERIES LEGENDARY WHEEL ONLY
1966-1971 FAIRLANE FAIRLANE, TORINO, 70 1/2 FALCON, W/ 1007-34 SERIES LEGENDARY WHEEL ONLY
1948-1979 F1 W/ 1007-34 SERIES LEGENDARY WHEEL ONLY
'68 Diamond Blue Fastback
I've been looking for some center caps with the GT emblem to fit Wheel Vintique Magnum 500s, No luck :confused:
Discussion Starter · #8 ·
Thanks David. I see the difference between the 2 wheels now. I'm guessing that the adapter kit Jerry1834 mentioned above would work with either wheel. I'll have to look into it.
1970 Mustang sports roof
Does anybody know what center caps fit the Legendary Magnum 500 Aluminum wheel (Magnum 500 Wheel)? Am I limited to center caps that are specifically for the Magnum 500 (Center Caps)? I wanted to get these Scott Drake C5ZZ-1130-BK - Scott Drake Styled Steel Hub Caps or these Scott Drake C5ZZ-1130-W - Scott Drake Styled Steel Hub Caps but I don't know if they will fit.
If you get it figured out please post a reply, as I am sitting here wondering the same, all the information posted is just confusing me more 😆
How about these ??
793795
OK, it is not real, I made this up using the plastic cap that came with my GT9 wheels, a GT emblem from a pop-open gas cap, and a cut out center of a brushed nickel round door cup. Need to submit this to Scott Drake as I think this would be a popular option.
To make a set of 4 would be $$ as the gas cap GT emblem was pretty expensive, but I no longer see it on NPD's site as a separate part.
Doug
Doug
1 - 10 of 10 Posts
